4banger Turbos vs. 89 Mustang
#32
i used to do that with Hondas all the time when i had my stock 4-dr 1.5L non-vtec civic. id hang with dohc vtec's and ls motors til @ 90 and theyd almost have a heart attack when they would see that i was completely stock.
#33
I'd have to disagree about racing a turbo car from a roll. An n/a engine doesn't ever have to wait for a blower to spool, as soon as you whack the throttle you have all of your power on tap. Depending on how the turbo car is set up it may or may not be in a position to make full power. It's going to come down to how each individual car is set up. In the end racing any car that has a higher power to weight ratio than you from a roll isn't going to go well.
#34
but if you know how to drive, and you have a 5-spd car, youll be in a gear where as soon as you floor it, your turbo will be spooling. lets say for instance, you have an '03 Golf GTi with a GT28RS turbo setup and an '03 Golf GTi with a GT35R turbo setup. if theyre both in 2nd gear doing a roll, say @ 45, and theyre both taching @ 3500(these are just random numbers and im a euro car freak which is why i picked a GTi), when they floor it, say AT THE EXACT TIME, the car with the GT28RS will pull out at first, because its made to spool RIGHT NOW, while once you get higher in rev's, the GT35R will more than likely catch it and pass it just because a 35R turbo can sustain a LOT more power than a GT28RS which tops out @ 400hp. but the non-lag issue with the 28RS will give it immediate max boost which at that time will give it more horsepower until they reach whatever revs the GT35R makes the most power, however if the car with the 28RS setup is far enough in front, the other one may not catch it. turbos are a whole 'nother subject of their own. too much technical "stuff" to take into effect. haha. but i love the sound of them.
Diode Dynamics
28
05-26-2022 12:02 PM
