idle problem 92 5.0L efi convertible
Old 04-23-2009, 07:55 AM
jetblack88
jetblack88's Avatar
Default idle problem 92 5.0L efi convertible
i have a 92 LX convert it runs awesome
but if you let it set long enough to cool down
when u go to start it back up
it starts immediately goes to about 2500
then dies
you can restart as many times as you like but
it will do the same thing until you touch the gas
give it one burst
then it will idle
checked the tps sensor it is fine and its set at .94 volts at closed throttle
and theres no codes
i was thinking the act sensor but idk
i figured it would throw a code
jetblack88 is offline
Old 04-23-2009, 01:33 PM
94ford5liter
94ford5liter's Avatar
could be a bad distributor or your IAC. Do you have trouble starting it when it is warm? I'd bet the idle air control is part of your problem though if it shoots up to 2500 rpm, had the same issue on my old car and it was the IAC.
94ford5liter is offline
Old 04-23-2009, 04:01 PM
jetblack88
jetblack88's Avatar
no if its warm it will start just fine & idle just fine
it will idle when its cold but you have to give it that one throttle tap then it comes down and idles...its weird
Old 04-23-2009, 04:10 PM
jetblack88
jetblack88's Avatar
i got a spare iac off a 90 ford truck you think that will work
YoungStangsMan
09-05-2015 07:01 PM
Calizic
08-28-2015 01:46 PM
1st 4 eyed fox
08-24-2015 06:56 PM
stanngg
08-12-2015 03:43 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: idle problem 92 5.0L efi convertible
