Rear end clunk noise. Please help
Old 04-30-2009, 11:57 PM
83GT5.0
83GT5.0's Avatar
You are going to have to look in there. Same thing was happening to my 83'. Ended up being the carrier pin being going to hell, moving inside of there. I didnt know how the rear end held up so long in mine.
83GT5.0 is offline
Old 05-01-2009, 01:48 AM
08 Bullitt 2310
08 Bullitt 2310's Avatar
Originally Posted by 87FoxStang
Ok. I will just remove the cover this weekend and check everything out. How much slop should I allow?
The back lash checked with holding the pinion and moving the ring gear back and forth should be around .010 checked with a dial indicator meaning you should see very little movement between the ring and pinion.As stated though most wear will probably be in the cross pin,spider and axle.
08 Bullitt 2310 is offline
mtgldr
02-03-2024 09:00 PM
bjdutch2005
03-24-2017 03:38 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Rear end clunk noise. Please help
