water pressure installation!!
Old 05-02-2009, 09:35 PM
JUSTIN_5PNT0
JUSTIN_5PNT0's Avatar
Exclamation water pressure installation!!
I need help on locating the water pressure sender unit below the lower manifold on my 87 vert because I'm thinking of buying a water pressure gauge because my water temp gauge on my dash doesn't work!! Any advice and diagrams d be greatly appreciated!!
JUSTIN_5PNT0 is offline
Old 05-02-2009, 09:46 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
wtf are you talking about?? water pressure sensor??. you mean temp sending unit??
mjr46 is offline
Old 05-02-2009, 09:58 PM
JUSTIN_5PNT0
A mechanic I know says inorder to install a water tempature gauge then you need to locate the sending unit..? So how do you install this gauge?
Old 05-02-2009, 10:02 PM
mjr46
mjr46's Avatar
well than say so...no such thing as a water pressure sensor, anyway, the sending unit is a one wire sensor at the front left corner of the lower intake manifold., remove it and install your new sender there
mjr46 is offline
Old 05-02-2009, 10:42 PM
JUSTIN_5PNT0
Is there any sort of piks of this unit so I can spot it? It's on the left side when you open the hood?
StalkerGT
09-25-2015 02:41 PM
TimeLord101
09-04-2015 09:27 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: water pressure installation!!
