Bell housing removal
Old 05-05-2009, 03:03 AM
Ninety5five0
Ninety5five0's Avatar
Default Bell housing removal
Whats up guys ? I havent been on in a LONG time. Good to be back! Kindof.... I hydrolocked my motor last week when it flooded really bad in Houston... Dropped the motor and tranny today, all went good. But how in the world does the bell housing come off the block ? Prolly a stupid question, but damn, i cant get that thing off, and my haynes manual doesnt say anything about it... I appreciate all the input. Thanks.
Ninety5five0 is offline
Old 05-05-2009, 11:38 AM
86HOGT
86HOGT's Avatar
I assume the trans is off the bellhousing?
There are dowel pins that may have rusted real bad with the flood. Try the gentle touch of a prybar and hammerto see if you can start the seperation process.
Pics may help as well.
86HOGT is offline
Old 05-05-2009, 11:45 AM
Tony71502
Tony71502's Avatar
A couple decent wacks on the bell housing shouldn't damage it and will knock it loose from those dowel pins.
Tony71502 is offline
Old 05-05-2009, 12:53 PM
Ninety5five0
Yea, the tranny is off. I'll try to beat it off.... not too hard, but i'll see whats up. If i can figure out a way to get pictures to this computer I post some... Its a mac and i've always used windows, and i cant get my digi cam or cell phone connected to this thing... Thanks for the input.
Old 05-05-2009, 01:26 PM
j-wigg
j-wigg's Avatar
the starter needs to be taken out (2 bolts holding that on). the splash shield has a few screws that need to be taken out (Fairly small, i think 4 of them). then the bell housiing has 6 screws. 2 longer ones at the top and 4 more going around the sides to the bottom. usually easier to have the clutch fork out if its still in also.
j-wigg is offline
Old 05-05-2009, 02:58 PM
Portmaster
Portmaster's Avatar
Unbolt the starter. Take out the 6 bell housing bolts and if it doesnt fall off smack it with a rubber hammer or a plastic dead blow hammer. If you don't have either one of those hold a small block of wood against it and hit it with a Big hammer. Just double check that all the bolts are out. We all miss one from time to time when you do it everyday
Portmaster is offline
Old 05-05-2009, 04:19 PM
Ninety5five0
They are all out, starter is off, and all other bolts around are off.... I'll wack it a few times.
Old 05-06-2009, 12:04 AM
Ninety5five0
I got it off. It was seized up on there pretty good,i just hit it a few good times, and pried around it, then was able to pull it off by hand. Just spend an hour or so takin off the lower intake and heads... There was a lot of water, i'm suprised it stayed running as long as it did. I got about a gallon out of the exhaust, and there was even more on top of some of the piston... Cant wait to drop the pan and see how that looks... Thanks for all the input.
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Bell housing removal
