1988 PCV Modification
Old 05-08-2009, 10:25 PM
Grayrage
Grayrage's Avatar
Default 1988 PCV Modification
I have a 1988 stang w/ some issues. It has had a lot of performance work done Holley injection holly heads stroked etc.... anyways guy who did the work did not finish the job and cannot be found. So... here is my first problem
Noticed there was oil in the intake, checked the oil level... ok saw that there was no PCV valve.. it has aftermarker valve covers and there is only one nipple coming off of the cover... How is air supposed to flow in and the pcv valve let air out with one fitting??? An oil cap with a breather?
Grayrage is offline
Old 05-09-2009, 04:03 PM
Grayrage
Grayrage's Avatar
So no suggestions?
Grayrage is offline
Old 05-09-2009, 04:07 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
post a pic of the intake your using
the pcv is supposed to be in the lower intake at the rear
see where this hole in the lower intake is that will be in the rear
look here in this pic in between the numbers 7 and 8
rmodel65 is offline
Vrooom
02-21-2016 05:25 PM
lmurf60
09-24-2015 10:07 PM
Ipaman
09-22-2015 07:01 AM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
YoungStangsMan
09-05-2015 07:01 PM
Quick Reply: 1988 PCV Modification
