Backfire After Kenne Bell Install
Old 05-16-2009, 08:37 PM
jthorn9
The Godfather
jthorn9's Avatar
Default Backfire After Kenne Bell Install
OK, engine runs fine, idels great, and revs up great, but when I took it for a test drive I got an occassional back fire, didn't go but around the block and didn't even get out of third gear. With that said, I'm fairly sure it might be the timing but want a second opinion. I believe the timing is at 10, and not 15 as stated, but I have a question, is timing read from the center of that little u in the timing marker, or is it read from the very top of the marker. If it's from the center then the timing is 10, if it's from the top then it's 15.
Also, there was no pinging at idel or while driving, engine temp has held steady at just under 200 degrees f. and my vacuum read 18 hg. Now where in the hell do I plug in my boost gague to measure boost, because the hole I pluged it into read 18 hg at idel.
jthorn9 is offline
Old 05-16-2009, 08:38 PM
jthorn9
The Godfather
jthorn9's Avatar
Oh, fuel pressure is a steady 35 psi at idel, and just over 40 when reving up.
Oh, also, if somebody could upload a pic as to where the timing is read, that would be the most helpful.
jthorn9 is offline
Old 05-16-2009, 08:59 PM
AdderMk2
Banned
AdderMk2's Avatar
https://mustangforums.com/forum/6207307-post17.html
from the top of the pointer
AdderMk2 is offline
Old 05-16-2009, 09:03 PM
jthorn9
The Godfather
jthorn9's Avatar
Wow, found the problem, thanks adder, KB book clearly states no more than 10*.
jthorn9 is offline
Old 05-16-2009, 09:09 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I would back it down to eight to be safe with the fmu. Then see if you have any pinging at 1/2 and 3/4 throttle.
TrimDrip is offline
Old 05-16-2009, 09:12 PM
jthorn9
The Godfather
jthorn9's Avatar
Well I reved it up to 5000 RPMs, in neutral, and no pinging at all, my hearing isn't so great, but I had my cousin stand in front of the engine with the hood up, and he didn't hear anything.
jthorn9 is offline
jthorn9
The Godfather
jthorn9's Avatar
Oh, but I think I'm going to back it down to 8*, that's where most people I've read articles with have found the most safety with a KB.
jthorn9 is offline
Old 05-16-2009, 09:15 PM
86HOGT
86HOGT's Avatar
No boost at idle, btw.
86HOGT is offline
Old 05-16-2009, 09:16 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
your gonna need to drive it.
My car has a 3.27 gear. I put it in 5th doing 20 mph and found it.
TrimDrip is offline
Old 05-16-2009, 09:20 PM
jthorn9
The Godfather
jthorn9's Avatar
But the question remains, where do I plug tube for boost?
jthorn9 is offline
Quick Reply: Backfire After Kenne Bell Install
