new tranney leaking?
Old 06-17-2009, 02:10 AM
pk222
pk222's Avatar
Default new tranney leaking?
hey guys, I just bought a reconditioned transmission and tried filling it with fluid before I put the tranney in. I realize this was a bad Idea now but with any angle it poured out like crazy. with the 3 clutch jobs I've done I've never had problems like this with the fluid straight poring out. Maybe because the seals had been broken in but should this be ok? I ended up not being able to get the trans in because I tried putting the bellhousing in before the transmission to try to avoid the bellhousing to block dowels but now I don't think thats possible.
pk222 is offline
Old 06-17-2009, 02:17 AM
mstngsule68
mstngsule68's Avatar
get one of those fluid pumps, only like 10bucks and they come in handy at times.....
mstngsule68 is offline
Old 06-17-2009, 02:43 AM
pk222
pk222's Avatar
ya I know, thats what I'm gonna do now. I was trying to avoid having to deal with the bellhousing to block pins
pk222 is offline
Old 06-17-2009, 03:11 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
what you do, is leave the fluid out then once its in, you remove the fil lhole on the side of the transmission and remove the lower shifter. then you pour fluid in the tranny untill it runs out of the fill hole on the side and your done easy as pie
rmodel65 is offline
Old 06-17-2009, 12:29 PM
pk222
pk222's Avatar
easier said than done on mine.. this is on my 95 and it has the shorter input shaft and the bellhousing out of a fox. I had to have the tranney shop swap it to the shorter shaft because I I didn't bring the bellhousing. With the way it is, I cant remove the shifter with the tranney in place.
I didn't do this on purpose but thats what the previous owner did and if I didn't stay with the set up he had I would of had to drive another 7 hour round trip to get another bellhousing.
pk222 is offline
Old 06-17-2009, 03:09 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
or you could have bought a used bellhousing for 100$ ???
rmodel65 is offline
Old 06-17-2009, 03:29 PM
pk222
pk222's Avatar
its too late now it already has the shorter input shaft in it and the place where I had it done is over 3 and a half hours away.
I'm just trying to find out if it should be leaking like it is. I'm guessing in the back it is because I don't have the driveshaft yoke in but I don't think it should leak as bad as it is from the front. I lifted the tranney from the back to put the tranney/midpipe mount assembly on and it started pouring out.
pk222 is offline
Old 06-17-2009, 03:30 PM
pk222
pk222's Avatar
double post
pk222 is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: new tranney leaking?
