Does it look like my axle is bent?
Old 06-18-2009, 10:18 PM
  #21
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
^^I assume he needs to work it all out with Amin??
mjr46 is offline
Old 06-21-2009, 01:15 AM
  #22
Jfsram
Jfsram's Avatar
The inner surface on the outer diameter are not critical dimensions on an axle flange.
The machined surface of the side the faces the drum is important.
Place a dial indicator on it. You can also do this with the wheel on. Just measure the runout at the bead of the rim.
Jfsram is offline
Old 06-21-2009, 01:33 PM
  #23
ryan_89_mustang
ryan_89_mustang's Avatar
Yeah I don't have a dial indicator but the axle flange was moving the same on the outer flat part. With the tires on and the car idling in first the tires wobble side to side.
ryan_89_mustang is offline
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
lincolnshibuya
09-24-2015 10:46 PM
09-24-2015 09:18 PM
09-10-2015 08:39 PM
Quick Reply: Does it look like my axle is bent?
