Drive shaft removal
do this, get 4 jack stands and 1 jack....jack up the rear as high and safely as possible, jack the front up as high and safely as possible....leave the car in gear....take the bolts u can out...put it in neutral...turn the driveshaft to when u can get the others out...put it back in gear....take the others out...then pop the shaft off...put the bolts back in the flange where they came out...then pull the yoke out and put a bucket under the tailhousing if it leaks....let it all pour out...THERE DONE shaft out and ur still alive..
Gary Ugarek
63
12-11-2015 02:01 PM
