intake
intake
I have a cobra upper and lower intake on my 94 gt and i was thinking about going with a holley systemax 2 upper and lower. good or bad decision? pros and cons? what kind of gains/loss will i see?
Do you have a stock cam? If so, I would keep the Cobra intake. The stock cam and that Cobra will help give you a nice low torquey feel. If you have a higher revving cam, then I would go with the Holley to give you a much longer power curve.
Okay. The truth is, both intake manifolds are good. Which Cobra intake do you have? The one with an elbow connected(94-95 cobra) or the Fox body Cobra(93)? The Cobra is good for making low end power and torque. Past 5500rpm and it falls flat. A good porting job can really wake them up as well as there is plenty of room for porting. But you can only open up the ports so much. I have a GT-40 intake w/an unported lower(same as Cobra) on my supercharged 95 GT and it retains great street torque. But it is a restriction. And this is where a Holley would really shine. The ports are much larger and it is meant to rev. You can take them into the 6000rpm+ range. It's something that would really benefit my car. In your case, I would stay with the Cobra unless you plan on any forced induction down the road. You'll have great street power.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
