Breaking Clutch Cables
Old 08-23-2013, 01:34 PM
  #21
Strokednforged
Strokednforged's Avatar
Thumbs up Clutch cable replacement!
Originally Posted by Js88lx
DO NOT.., I REPEAT DO NOT BUY ANY FROM AUTOZONE PERIOD!! I went thru 3 of those within 3 weeks.. disgusted! Any aftermarket will do!
((UPDATE) well I got my new ford racing clutch cable installed today after buying a cheap autozone one that broke in 5 mins (LITERALLY) so far so good! I have a highly modified,supercharged fox n as I previous
Y posted snapped the existing cable, replaced it which broke in 5 mins. I now have the new ford racing cable in, although I have not done a smoke show yet, the cable is working well (DAYN1) my pro 5.0 shifter actually seems to b shifting much cleaner n smoother as well? I'm guessing it was a lil stiff n resistant fealing due to the previous cable being on its way out? Which me luck friends t2yl!!! Strokednfordged.
Strokednforged is offline
Old 01-20-2014, 01:01 PM
  #22
scanderson62
scanderson62's Avatar
i have an 01 bullitt with a similar problem and i do have some wear under the dash. do you have the solution to this problem. im on my third cable in 7 months. my new one is a maximum motorsports OEM with fire wall adjuster and new quadrant. this is the first time i'll be trying to use a not OEM ford manufactured part.
scanderson62 is offline
Old 01-20-2014, 03:40 PM
  #23
camaroeater
camaroeater's Avatar
The Maximum motorsports clutch cable is the best, it was manufactured for MM by the original Ford vendor. I had a ford racing one for a day and switched to the MM. The pedal effort was reduced with the MM cable.
camaroeater is offline
Old 01-22-2014, 03:03 PM
  #24
Boss_Hotrod
Boss_Hotrod's Avatar
Yes MM setup all the way. Ive broke countless cables and then went to the MM setup a couple years ago and havent had a single problem since.
Boss_Hotrod is offline
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
kevsgt
10-09-2015 10:12 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Breaking Clutch Cables
