valve spring help 89gt 302
Old 07-19-2009, 09:19 PM
fastfreake58
fastfreake58's Avatar
Default valve spring help 89gt 302
hey,i finnally found my trouble i have a valve spring broke. but im wondering if anyone knows iff the springs differ for gt40 heads?napa only has the one listing.
fastfreake58 is offline
Old 07-19-2009, 09:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if one spring is broke, I'd replace all of them as they are weak and fatigued most likely and upgrade them to some performance ones as the stock cam could benifit from such
mjr46 is offline
Old 07-19-2009, 09:30 PM
fastfreake58
hey,
thanks,i have a performace cam in there those that matter?
Old 07-19-2009, 09:41 PM
mjr46
mjr46's Avatar
then you need to state that in the first post and what it is.....FYI you have a broken valve spring most likely due to the fact you are using stock springs with a performance cam and since springs may not of been set up to cam requirements , coil bind most likely occured and that's why you now have a broken spring, you can't shop at napa for what you need......list the cam and then we can help get you the springs and specs that they need to be installed at on the heads
mjr46 is offline
Old 07-19-2009, 10:09 PM
fastfreake58
i really dont know what kind off cam it is and what type off springs were use when it was done bc ive only had the car for a few months now.all i kno its a after market cam and gt40 heads.is there any way i could know what type off spring to use? .
thanks for ure help
Old 07-20-2009, 08:03 AM
Joel5.0
Joel5.0's Avatar
thanks for ure help
Yup.... degree the cam, find out the open/close events @.050", .100" and .200" tappet lift, total tappet lift (= ID the cam).... and then check what springs will support those specifications.
Joel5.0 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: valve spring help 89gt 302
