a/c and smog elimination
Old 07-26-2009, 10:00 AM
Projectquick
Projectquick's Avatar
Default a/c and smog elimination
I'm trying to eliminate the smog pump and a/c compressor out of my engine bay and find a way to run the serp. belt to the alt., the power steering, crank, and water pump. Is there any way to just get a smaller belt and run it, or do I have to get the bypass pulleys. I found them on summit for like 70-80 bucks apiece, but I really don't feel like spending that much on two useless pulleys. I've also been checking on ebay, but again I think 30 bucks each is a little expensive. I've heard I can go with just the a/c bypass, and just use a smaller belt to eliminate the smog pump all together and run the belt right from the crank to the alt., is that true?
Projectquick is offline
Old 07-26-2009, 10:07 AM
Tony71502
Tony71502's Avatar
Buying new pulleys is a complete waste of money. Buying an A/C delete kit, on the other hand, is not. The delete kit for the A/C is two brackets that relocate the powersteering pump to where the a/c compressor is. That is where the power steering comes on factory non a/c cars. I'll take a picture of mine... but just switch the way the belt is run on the water pump/crank and then run the rest as normal.
Tony71502 is offline
Old 07-26-2009, 09:57 PM
Projectquick
+BUMP+
Old 07-26-2009, 10:23 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
there's a guy on here 86gtH.O i BELIEVE who has the set up you'd want, I'm not a fan of it but he can tell you how to do it
mjr46 is offline
vargas
06-17-2017 12:17 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Teddi
09-29-2015 12:24 PM
wawagner82
09-13-2015 09:02 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: a/c and smog elimination
