Water Pump Question
Old 07-27-2009, 10:52 PM
mattkoly
mattkoly's Avatar
Default Water Pump Question
On my 94 Cobra i know for sure i have a bad water pump due to coolant coming from weap hole, my question for you mustang experts is...
What is the capacity of the radiator?
reason i ask is because i had to add about 2/3 gallon to radiator and I would like to know if I ran it dry or if i had some left.
I belive i have a 3 row brass radiator.
mattkoly is offline
Old 07-27-2009, 11:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
there is coolant in the block as well, as long as you didn't overheat it to no end it doesn't matter what the radiator holds, but the radiator often doesn't hold 2 gallons
mjr46 is offline
Old 07-27-2009, 11:12 PM
mattkoly
mattkoly's Avatar
thank you mjr46.
I am confused about your statement about not holding 2 gallons, i was saying i added 2/3rds of a gallon, not 2-3. was that your understanding?
also from looking at water pumps online, it looks to me like the water pumps recircs water in the block as well as bringing it in from radiator (when thermostat opens) is this what saved me or am i wrong on my assumption of how the pump works.
mattkoly is offline
Old 07-27-2009, 11:16 PM
mattkoly
mattkoly's Avatar
I'm going to bed, thank you for your response, i will check this out in the morning.
Have a good night.
matt K.
mattkoly is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
9550
10-26-2015 05:01 PM
96stang3.8
09-10-2015 06:42 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Water Pump Question
