engine noise need help
Old 07-29-2009, 12:40 AM
cheetha94607
cheetha94607's Avatar
Default engine noise need help
after having fun and tuning my engine myself. my electric fan detach itself and my car was over heating look at my oil pressure gauge and it was at 0. after 10-20 min of sitting the car was at 25psi at idle and was making this knocking noise only when accelerate .need all the help i can get .please look at my video. http://www.youtube.com/watch?v=MJDd-Rgy2mI
cheetha94607 is offline
Old 07-29-2009, 12:47 AM
Liquid_02
Liquid_02's Avatar
Hard to hear anything in the video so I can't really help you out with your noise. If your oil pressure was indeed at 0, I'd tear the engine down, something WILL be hurt. Repair it before you cause even more damage. Only take a few seconds without oil pressure to start hurting the bearings
Liquid_02 is offline
Old 07-30-2009, 05:36 PM
cheetha94607
does the 302 headers bolt to a 351 and align correctly. also what is needed to install a 351w
Old 07-30-2009, 06:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
lol when I read your post I was like WTF??? ALIEN correctly, I thought of little green martians running around on your motor then it hit me, you meant "align correctly".....lol....anyway, run a mech pressure test before condeming a pump , oil system issue.
mjr46 is offline
Old 07-31-2009, 01:15 AM
cheetha94607
ok so my compression is 155-170 in all 8 cylinders. cylinder 8 155 and the rest is 165-170. so i remove the engine and will have a update tomorrow.
Old 07-31-2009, 01:24 AM
Liquid_02
Liquid_02's Avatar
They'll bolt to it but won't fit the body. Not much is really needed, if you had a long block with balancer and flexplate/flywheel, it'd be a lot like installing a 302, all you'd have to fight with is exhaust and fuel system, then hood fitment.
Old 07-31-2009, 07:52 AM
mjr46
mjr46's Avatar
...that small difference in compression is not enough difference to cause an issue, knocking noises, I'd look at bearings and wrist pins
mjr46 is offline
Old 08-03-2009, 03:23 AM
cheetha94607
OK so i torn down the engine and found worn bearings both mains and rods. crank would need to be re-polish and i would also need new gaskets.but at this point i will be getting a 351w/408w just have to save and do it correctly. oh and since i have everything out the engine compartment wire hiding and removing all unused items are in the process. pic of the bearings should be posted below.
Old 08-03-2009, 03:29 AM
cheetha94607
Default bad bearings pictures
here are the pictures:
Attached Thumbnails engine noise need help-mustang-07-28-09-build-019.jpg   engine noise need help-mustang-07-28-09-build-020.jpg   engine noise need help-mustang-07-28-09-build-024.jpg   engine noise need help-mustang-07-28-09-build-026.jpg   engine noise need help-mustang-07-28-09-build-028.jpg
Old 08-03-2009, 11:27 AM
Liquid_02
Liquid_02's Avatar
That's too bad, but that's what I had thought would happen. Doesn't take long without oil pressure to destroy an engine. Glad to hear you're joinin the 351 club though
Nick Oliver
10-17-2018 04:22 AM
bjdutch2005
03-24-2017 03:38 AM
Pyrate Dave
09-10-2015 07:30 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: engine noise need help
