help - loss of all throttle at anything over idle.
I have a 87 hatch that has been running fine for the last two months. recently, it has started cutting out at anything over 1/16 to 1/8 throttle. it starts fine, and drives fine down the neighborhood streets, but once i have to push the gas to get up to even 40, it starts to cut out bad. it will cut out, i will release the throttle, and once i push the gas again, it does the same thing. it does it so hard it barks the tires. i have checked all of the obvious stuff, i.e. loose electrical, air filter(its not wet, which has happened in my exploder once), fuel filter, and so on. it is a fice speed with decent opwer, but i cant figure it out. any help would be appreciated.
- Check fuel pressure.
- Run the DIY KOEO/KOER self tests.
- Check manifold vacuum with gauge engine idling and while accelerating.
LUK
LUK
JDWalton
09-24-2015 08:47 PM
