Rearend HELP
Old 08-09-2009, 07:54 AM
stanglx2002
stanglx2002's Avatar
Default Rearend HELP
I just put in a rearend in my 85 T-top that came out of a 87 Mustang 4 banger and when i opened it up to change the fluid everything was nice and clean and looked to be new which is great.
Well after I put the rearend in the car and I spun the axles I heard a ticking noide from inside the rearend like the gears were clicking together, so I climbed under the car to get closer to the sound and I spun the yoke where the driveshaft attaches to the rearend and it didnt make a noise.
What makes a noise when you spin the axles but DOESNT when you spin the yoke where the driveshaft attaches??????
Is it an open differential????
stanglx2002 is offline
Old 08-09-2009, 08:21 AM
AdderMk2
Banned
AdderMk2's Avatar
congradulations... you replaced a 7.5... with another 7.5...
what a waste of time
AdderMk2 is offline
Old 08-09-2009, 09:16 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
that is a single track/open rear, I'd of put a t-loc in min.
mjr46 is offline
Old 08-09-2009, 10:42 AM
stanglx2002
Is it bad to have that in a DD??
Whats bad about those rearends??
Also why does it make the clicking nosie??
Old 08-09-2009, 03:19 PM
Liquid_02
Liquid_02's Avatar
They're terrible... Ford quit putting them in behind the 5.0's for a reason, and banished them to a life behind the 4-bangers.
Just the spider gears spinning, you have an open diff.
Throw that rear in the garbage and find an 8.8 with a posi.
Liquid_02 is offline
Old 08-09-2009, 04:51 PM
stanglx2002
So there isnt anything wrong with the rearend then?
Is going to be used for a 2.3T T-top that im going to use as a DD
I have been talking and asking questions on the forums and have gotten different answers as the rearend is bad and the rearend is fine bc its an open diff and is suppose to sound that way.
So is the rear fine or not??
Old 08-09-2009, 07:18 PM
Liquid_02
Liquid_02's Avatar
No there's nothing wrong with it
Old 08-09-2009, 08:26 PM
mjr46
mjr46's Avatar
it's fine for your intended use, heck I ran a 7.5 with guts out of an 85 in my 92 for 5 years and held up to over 200 passes of 4500-5500 k rpm drops at the track until it finally blew the spider gears out
mjr46 is offline
Old 08-10-2009, 08:03 AM
stanglx2002
My other rearend is a posi so should I fix the pinion seal in it and change the fluid and put that one in there?
If so what do i have to do to replace the pinion seal?
67LimeCoupe
09-30-2015 04:46 PM
67LimeCoupe
09-21-2015 06:34 PM
67LimeCoupe
09-02-2015 08:02 AM
jhutch
08-19-2004 05:57 PM
S_man_9
08-13-2004 12:32 PM
Quick Reply: Rearend HELP
