rear disc 5 lug conversion questions
ok so ive already convereted to 5 lug in the front and i want rear discs but with a working e brake. most of the online info is vague. i even found info on using caddy calipers
http://www.sn95brakes.com/5lug.php
im doing it all from junkyard lincoln stuff and ranger axles. its pretty simple flipping the calipers but not the e brake and i am not too sure about the master cylinder and related stuff.
anyone running the mark 7 rear discs without a off the shelf kit?
so the 97 disc set up swaps right in? i want stock axle width, not sn95. im not swaping axles.
The parking brake is completely independent of the front suspension/braking. The only thing that changing front calipers will do is require more brake fluid. Changing spindles requires new hubs/calipers/rotors.
Axle swaps are pretty quick if you know how. You're going to need a better master cylinder.
11-10-2015 11:39 AM
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
09-02-2015 08:40 PM
