torque specs and sequence for heads?
Old 08-15-2009, 04:46 PM
cobrakiller306
cobrakiller306's Avatar
Default torque specs and sequence for heads?
does anybody know off hand the torque specs and sequence for trickflow aluminum heads, they are bolts not studs.
cobrakiller306 is offline
Old 08-15-2009, 07:03 PM
Tony71502
Tony71502's Avatar
Call TrickFlow?
Tony71502 is offline
Old 08-15-2009, 07:49 PM
jthorn9
The Godfather
jthorn9's Avatar
For an N/A engine it will be 60-65lbs of torque using thread lubricant (the silvery stuff in a bottle at autozone that's used to allow bolts to slide easier back into the block), and 80-90lbs of torque using 10-30 oil as your lubricant. Sequence is: (bolt numbers)
rear of motor
10,9
8,7
6,5
4,3
2,1
front of motor
5,6,3,4,7,8,1,2,9,10
Torque settings is 25lbs, 40lbs, 60lbs (80lbs if using oil).
jthorn9 is offline
Old 08-15-2009, 10:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it's a good idea to use arp moly lube for even torque on the bolts
mjr46 is offline
Old 08-15-2009, 10:21 PM
19stang88
19stang88's Avatar
A haynes book contains this information, buy one so you can refer to it when you need to, they are handy. But asking here is a good idea too.
19stang88 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
kevsgt
10-09-2015 10:12 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-30-2015 03:48 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: torque specs and sequence for heads?
