timing cover gasket
Old 08-17-2009, 09:14 PM
94mustang94
94mustang94's Avatar
Default timing cover gasket
my 94 gt is leaking coolant right behind the timing cover. i was wondering what all is entailed in changing the gasket out? and the gasket set that i bought has like 7 gaskets in it. whats the deal with that. i though it was just one gasket
94mustang94 is offline
Old 08-17-2009, 10:30 PM
Liquid_02
Liquid_02's Avatar
Well if you got the timing set, it will come with probably four w/p gaskets (as there are a couple different w/p's, and they take 2 gaskets) a timing cover gasket, and the seal. To get it off, remove the W/P if you feel like it, I would to replace the gasket on that while I'm at it, if you don't want to, just remove the 4 long bolts on each side of the pump. Balancer, oil pan bolts and the rest of the timing cover bolts and it's out.
Liquid_02 is offline
Old 08-17-2009, 11:07 PM
94mustang94
where does the round seal that comes in the kit go. a guy put a step by step process on the internet but didn't mention the seal that looks like a pinion seal
mirandaandjimmy
11-16-2015 08:51 AM
waid302
09-14-2015 11:19 AM
YoungStangsMan
09-05-2015 07:01 PM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: timing cover gasket
