new cold air intake?
Old 08-20-2009, 04:17 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Originally Posted by JD1969
When we were running the Factory Stock car, we tried a ton of intake set ups. The one that worked best a 4 inch 90* bend off the the TB to a straight section of pipe, then the MAF with round, open filter. The filter actually ends up being right above the driver valve cover. Speculate all you guys want about how the hot air hurts performnace, but I have seen first hand on a dyno how the set up I described picks up both power and TQ. The hot air has little to do with things, it is about air flow and keeping as direct a path of air flow into the engine as possible. Fender mounts have too many turns in them.
An exception to this is with s/c's though. KB has a great tech write up on this in there tech section.
projectresto83 is offline
Old 08-20-2009, 04:57 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
I would think that is obvious, but on here nothing should be taken for granted.
JD1969 is offline
Old 08-21-2009, 01:02 AM
GGT
GGT's Avatar
Stay stock, it gets outside air already
GGT is offline
heslekrants
09-23-2015 04:02 PM
J.casone400
09-12-2015 10:01 PM
kevsgt
09-09-2015 06:20 AM
09-08-2015 11:50 AM
Quick Reply: new cold air intake?
