Water boiling over pretty bad..
Old 08-22-2009, 01:04 PM
chickenbutt
chickenbutt's Avatar
Yea, a "friend/brother in law" said it would help run cooler... guess he is wrong. goin to put it back in now...
chickenbutt is offline
Old 08-22-2009, 01:11 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
My toyota pick-up runs cooler with the failsafe thermostat stuck open. Doesn't mean it applies to your vehicle. If it had a brand new 500 dollar radiator, it would probably stay cool all the time with no thermostat or with a thermostat like mine stuck open.
TrimDrip is offline
Old 08-22-2009, 03:55 PM
chickenbutt
ok so i put the thermostat back in but now i need a new gasket. its shootin water out of one side
Old 08-22-2009, 04:07 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
rtv sealant works good
TrimDrip is offline
Old 08-22-2009, 04:08 PM
mattdel
mattdel's Avatar
silicone is fine, or get a gasket. just make sure to clean well.
mattdel is offline
Old 08-22-2009, 06:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
WTF?????YOU PUT IT BACK IN WITHOUT A NEW GASKET??? very least you should of used sealer.......oh well live and learn
mjr46 is offline
Old 08-22-2009, 06:12 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
How do you know it's overheating. What temp does it run at. maybe the cap is bad and letting coolant by-pass. And since you have no catch can, it leaks on the ground.
PRO50SC is offline
Old 08-23-2009, 10:19 AM
chickenbutt
it barely gets over the first two lines 130 or so and it doesn't really boil over it just rushes out.. its a brand new radiator cap.. no more than 50 miles on it.. and i put the stat housing back on without a new gasket b/c it looked pretty good still but i ended up taking it all back off and using the rtv sealant... Its suppose to be an easy job. but if yoiu guys have a vortech supercharger then the mounting brackets are like half an inch infront of the stat housing and pretty cramped right there.. And i have yet to start the car back up b.c the sealant said to wait 24 hours to fully cure.. and GOD knows I don't wanna take that thing off YET AGAIN.. Oh and wen I had the stat housing off which is new to, i got it wen i got the radiator cap. it has like white little bubbles or something in it.. looks nasty or something you would see like on a coral reef or something. ?? any ideas what that could be?? maybe I just need to flush my whole coolant?
Old 08-23-2009, 11:41 AM
mjr46
mjr46's Avatar
130?? it's not running hot...where is coolant rushing out?? the little nipple on the radiator neck where the overflow tube should be connected??
mjr46 is offline
Old 08-23-2009, 09:33 PM
chickenbutt
yes thats where..
Quick Reply: Water boiling over pretty bad..
