Are these required?
Old 08-21-2009, 10:07 AM
Tony71502
Tony71502's Avatar
Default Are these required?
Do I need the sleeves for the cylinder head bolts that are found on the engine block? I have two on one side of the block, but the other side of the block only has one sleeve.
Are these sleeves solely for the purpose of lining up the cylinder head? I can't see them providing any real seal against coolant considering they are not a solid sleeve(I think there is a slit in them to ease installation) and they are also only located on two of the 5 lower head bolts.
If I need to get the one I am missing, do auto parts stores usually have them?
Tony71502 is offline
Old 08-21-2009, 10:25 AM
Derf00
Gentleman's Relish
Derf00's Avatar
Those sleeves are used for just that...aligning the head when you put the head on.
Other than that they serve no other purpose.
Derf00 is offline
Old 08-21-2009, 11:00 AM
primetime5.0
primetime5.0's Avatar
machine shops have them.. or trick flow has upgraded ones
primetime5.0 is offline
Old 08-21-2009, 11:01 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
it aligns the head gasket and cylinder heads.
FivePointOhh is offline
Old 08-21-2009, 03:08 PM
lxman1
lxman1's Avatar
Makes assembly a whole lot easier!!! Hard to hold a head gasket in place while wrestling the head into place.
lxman1 is offline
Old 08-21-2009, 09:20 PM
mustangsneverdie
mustangsneverdie's Avatar
are you sure it's not still stuck in the head
mustangsneverdie is offline
Old 08-21-2009, 09:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you need them, they keep the head gasket centered and from shifting while torquing the head down
mjr46 is offline
Vrooom
02-21-2016 05:25 PM
robcy
Suspension
10-27-2015 11:14 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
warwickbass
09-20-2015 04:51 PM
Quick Reply: Are these required?
