need help with my t-5
Old 08-22-2009, 07:32 PM
95cobrasaleen95
95cobrasaleen95's Avatar
Default need help with my t-5
hi, i just installed a aluminum driveshaft in my 95 cobra and the next day on my way to work i was on the freeway going bout 80 in fifth gear when my tranny started to shake and smoke came out when i checked it out my aluminum driveshaft had fallen from the front u joints had seperated so it i guess it was hitting my tranny and craked the tranny case ...has anybody been trough this was it my tranny or the driveshaft at fault here..should install the same driveshaft with new u joiints or keep the stock..... need help thanks....
95cobrasaleen95 is offline
Old 08-22-2009, 07:45 PM
Jfsram
Jfsram's Avatar
I'd have that driveshaft checked for balance, correct length and make sure it's the correct input yoke before I used that again.
Is there locks in the caps?
Jfsram is offline
Old 08-22-2009, 07:48 PM
95cobrasaleen95
yes they where clips on the caps ....u think the driveshaft was unbalenced
Old 08-22-2009, 07:49 PM
95cobrasaleen95
the caps from the driveshaft fell out so the driveshaft was loose spinning around ..the yoke was still in the tranny
Old 08-22-2009, 09:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
were all the bolts tight?
mjr46 is offline
Old 08-25-2009, 12:32 AM
95cobrasaleen95
yes but it fell off from the yoke the front part of the drive shaft the yoke was still in the transmission
Old 08-25-2009, 02:09 AM
hillbilly pony
hillbilly pony's Avatar
sounds like the retaining bolts either broke or backed out...thats about the only way that can happen...
hillbilly pony is offline
Old 08-25-2009, 07:02 AM
mjr46
mjr46's Avatar
could of been a u-joint improperly installed
mjr46 is offline
Old 08-25-2009, 04:55 PM
mattkoly
mattkoly's Avatar
+1 on that one, the caps fell out, you didn't break a U-joint, so the retaining clips had to be missing. Do you have pictures?
mattkoly is offline
settled4automatic
09-24-2004 10:51 PM
settled4automatic
09-22-2004 03:59 AM
mcgyver8062
12-31-2003 08:56 PM
smithSHO
12-12-2003 03:10 PM
DougBlevins
03-24-2003 03:42 PM
Quick Reply: need help with my t-5
