Gears?
Gears?
Originally Posted by Pitviper100
well then since your good with gears questions what gears would be good for my 86 5.0 GT ( 5-speed)???? 3.55 or 3.73?
Gears?
ohssquik02... I do NOT have the correct speedo or tire diamater on my car. BUT, I did use my GPS to show me how fast Iwas going. The GPS shows 70mph @ 2650 rpm's. This is the same GPS that Itrust to show meexactly where the runway is when I am comingin on a night flight. And the GPS is more accurate than any speedometer on any car ever built. </P><edited><editID>jhogan2424</editID><editDate>37943.5812384259</editDate></edited>
Gears?
Originally Posted by jhogan2424
ohssquik02... I do NOT have the correct speedo or tire diamater on my car. BUT, I did use my GPS to show me how fast I was going. The GPS shows 70mph @ 2650 rpm's. This is the same GPS that I trust to show me exactly where the runway is when I am coming in on a night flight. And the GPS is more accurate than any speedometer on any car ever built. </p>
Gears?
Since my 91 has 4.10's I have to stick up for them here. With the AOD 4th gear the highway stuff is really no big deal. Yeah if you cruise at 80/90mph you will be buzzing the motor a bit. But I drive mainly around town, stoplight to stoplight. Most street races end by 50/60mph(unless you want to lose your license). For that the 4.10's are king. More gear reduction, more acceleration. The only problem I have with 4.10 is having enough gear in the quarter when you're pulling 115mph+. 6250 comes up fast in 3rd gear with 4.10.
Gears?
Gears?
go with the 4.10's tiger...i have those in my cobra...they're great...they kick *** from light to light...gotta regulate those little kids ya know...especially in them rice burners...but im still able to drive it around town everyday...so if you want the umph but still drivable...4.10's, jenna
Gears?
QUOTE]you can hit 115 in third. damm i was only able to muster 102 out of it running 245/50/16s maybe now that i have my 26x10.5 etstreets maybe a little more speed since the tires are alittle taller.[/QUOTE]
I've installed 28X10.5 M/T Sportsman Pro tires to bring the RPM's down. Ideally you want your trap RPM a few hundred RPM beyond your HP peak. That will maximize your ET. With 245/50/16's on my car I was spinning the motor well past where I was making peak power. As your HP rises you either need a higher peak RPM or lower numeric gears. Every tenth helps.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
