Battery Draining Problem
Old 08-30-2009, 11:31 PM
XXC
XXC's Avatar
Question Battery Draining Problem
Some reason, something keeps killing my battery while the car is in the driveway.
Nothing is powered on.
Anyone have any ideas?
XXC is offline
Old 08-31-2009, 12:33 AM
ttocs
ttocs's Avatar
how old is the batt/alt?
disconnect the battery and hook up an amp-meter. It needs to be wired in series with the battery to work.
Now go to the fusebox and start pulling fuses one at a time. The normal current drain with the key off should be.1-.2 amps MAX. When you pull the fuse that is related to the current drain you will see the current on the meter drop to almost nothing. Now you have isolated what circuit is causing the problem it will make it easier to fix.
I had the same problem on my ranger last winter. Turned out to be a pressure switch for the ac system that was stuck and leaving the clutch for the ac compressor engauged.
ttocs is offline
Old 08-31-2009, 01:04 AM
XXC
XXC's Avatar
The battery was brand new, and the alt is brand new as well.
The car doesn't have stock wiring, I used a 93 4 cyl wiring harness (just for the electronics)
And my IGN is hooked up to a 12v switch.
XXC is offline
Old 08-31-2009, 01:56 AM
jjw88mustang
jjw88mustang's Avatar
http://flashoffroad.com/electrical/B...teryDrain.html
Thats what i used it worked for me.
jjw88mustang is offline
Old 08-31-2009, 08:22 AM
ttocs
ttocs's Avatar
have you triple checked the connections to make sure that they are not loose or corroded? if they are all good then it is time to get the amp-meter out.
ttocs is offline
Old 08-31-2009, 04:08 PM
turbosha
turbosha's Avatar
install a battery cutoff switch.looks cool and effective
turbosha is offline
Old 08-31-2009, 07:04 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
hook the multimeter in series to neg terminal and set multimeter to amps and current draw should be between 25-50 milliamps...if not pull fuses to narrow down the drain to a circuit
mjr46 is offline
Old 09-01-2009, 01:26 AM
XXC
XXC's Avatar
Now I need to find a multimeter.
XXC is offline
Granatelli Sales
01-20-2020 12:34 AM
zsmart
Convertible Tech
02-29-2016 08:33 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Battery Draining Problem
