Missing on cyl#2&3
Old 08-31-2009, 10:44 AM
zeegee66
zeegee66's Avatar
Default Missing on cyl#2&3
I have an '87 t-top hatch that is missing on #2&3 (middle of left bank from front of car). I have moved the injectors from 1&4 to the 2&3 location, just to see if it was the injectors themselves, but same outcome. missing on 2&3.
zeegee66 is offline
Old 08-31-2009, 01:22 PM
mattdel
mattdel's Avatar
next step would be moving plugs, then wires. you're on the right track.
only 3 possibilities left. plugs, wires, or cap.
mattdel is offline
Old 08-31-2009, 01:26 PM
loeryder21
loeryder21's Avatar
i had the same problem and it was the cap, the points were messed up. pretty cheap fix. check the wires and make sure the wire goes through the boot.
loeryder21 is offline
Old 08-31-2009, 01:41 PM
67mustang302
67mustang302's Avatar
Do a compression check on both cylinders.
67mustang302 is offline
Old 08-31-2009, 02:16 PM
zeegee66
zeegee66's Avatar
I apologize for not mentioning, all new wires, cap, rotor, and plugs as they were my first guess. double checked the gap, because we all kknow they are never right, even with pre-gap. Still no luck, anyone think maybe the harness? how could i check the harness without shelling out for a noid?
zeegee66 is offline
Old 08-31-2009, 02:28 PM
zeegee66
zeegee66's Avatar
Also, the car has been upgraded with the A9L box, not sure if that will help or not...
zeegee66 is offline
Old 08-31-2009, 03:25 PM
mattdel
mattdel's Avatar
compression test is next. its rare to see 2 cylinders bonk out at the same time from a compression issue, but its possible.
mattdel is offline
Old 09-02-2009, 02:35 PM
zeegee66
zeegee66's Avatar
Compression test told the tale. bad head gasket sharing the compression between #2&#3. oh boy. thanks for the help guys. now I just have to figure out which gaskets to use since the heads are gt40p and so is the intake. Any suggestions?
zeegee66 is offline
Old 09-02-2009, 02:41 PM
67mustang302
Fel Pro 1011's. There's a -1 and -2, one has a copper ring and is .039" compressed(I've been running that one for years with 0 issues) and the other is .041" compressed with a steel ring. If you ever plan on running boost or juice you could go with the steel ring for added safety, though there are people running the copper fire ring gaskets with juice/boost with no issues. Ultimately it's the tune that kills head gaskets, or just making crazy cylinder pressure for the type of gasket used.
Old 09-02-2009, 03:14 PM
zeegee66
zeegee66's Avatar
Thanks 67, i will use the copper, i am not using, nor do i plan on any boost or nitrous, just a fun daily driver. the intake gasket would just be stock for the explorer, and i will have to look around for the header gaskets for the gt40p head setup. I do appreciate everyones help again. If there is any other info you think of, post it, i will be checking.
zeegee66 is offline
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Missing on cyl#2&3
