89 gt wont start when hot
Starter Solenoid may be going.
I had a similar problem, then one day the solenoid got stuck and the car just kept cranking over and over on it's own. Replaced the solenoid to fix that and inadvertently ended up fixing the other problem as well. Don't you just love when stuff like that happens
Replaced solenoid and starter a couple years back before this issue cropped up. Starter turns flywheel, but no "fire". Have heard "ignition control module" mounted on distributor can lose integrity due to thermal insulation breaking down and not function when hot. Anyone dealt with this?
i have been driving the car more lately and the problem seems to come and go. but no matter what when the car is warm it will turn over quite a few times before it will start but when its cold it fires right away. i have checked the timing. the battery is brand new, and since it has a pro billet msd distributor it wouldnt be the module. i also noticed the coolant temp sensor has been replaced. I have not tried the starter solenoid yet but i guess that should be next
Fubar008 - just fyi - I replaced Ignition Control Module last night, and Autozone tested the old moduel which "FAILED". They indicated this failure would cause the car to not start when hot! Hopefully, this resolves my issue (cross your fingers) - sorry yours is still a mystery.
Will run like a top all over town, but then it won't start again until it cools down. It cranks and cranks, just never catches. Starts great after another hour or so. Battery/starter good and replaced coil. Still has same problem. Can fuel pump relay be easily replaced?
