can a stock fuel punp handle 24lb injectors?
Old 09-03-2009, 09:17 PM
9165pt0
9165pt0's Avatar
Default can a stock fuel punp handle 24lb injectors?
will the stock fuel pump on 87-93 5.0's handle 24lb injectors? i jsut got some and want to put them on, but not sure if the stock fuel pump holds it back
9165pt0 is offline
Old 09-03-2009, 10:18 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if you have a maf you need to swap it also to one calibrated for 24's and advise swapping pump
mjr46 is offline
Old 09-04-2009, 12:25 AM
luckythirteen13
luckythirteen13's Avatar
if you have enough mods to NEED 24s, then no, the stock pump isnt enough. if you just want to put 24s on because you have them but your motor is mostly stock, the stock pump will be fine.
what makes you think you need 24s?
luckythirteen13 is offline
Old 09-04-2009, 12:47 AM
9165pt0
9165pt0's Avatar
well i have a gt40 intake, and gt40 iron heads ported and polished, 70mm t/b, 73mm maf...and the car is already running lean. but that may be due to a vac leak. and i just got the injectors, so i was wondering if i should just put them on. but will they work better over the stock 19lb injectors if im using the stock pump still? would there be an advantage?
9165pt0 is offline
YoungStangsMan
09-05-2015 07:01 PM
5.0 kevo
09-03-2015 06:24 PM
iculookin
09-02-2015 12:34 PM
SYNY5TER
09-02-2015 01:35 AM
Redneck1465
08-08-2015 10:39 PM
Quick Reply: can a stock fuel punp handle 24lb injectors?
