TREMEC 3550 and reverse
Old 09-04-2009, 10:41 PM
67mustang302
67mustang302's Avatar
TREMECs are notchy, it's part of their design characteristics. GM SM was designed specifically for use in the manual TREMECs, which is probably why it's the best fluid to use in them Check the shifter too, if it's the factory one the main housing is 2 pieces(if it came with the factory one like I had) and if the bolts come loose you'll encounter shifting issues.
67mustang302 is offline
Old 09-05-2009, 04:44 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
OK guys, thanks for the info. I'm going to have a shop flush out the Redline and replace it with GM SM. I'll also have them check out some other transmission components to make sure everything is OK.
Thanks again for the great info!
mAnYsTyLeS is offline
Old 09-05-2009, 07:48 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
let us know the outcome
mjr46 is offline
Gene K
10-21-2015 11:37 PM
foxdude
09-24-2015 08:45 PM
maestro1024
09-21-2015 02:40 PM
LivingInThePast
09-16-2015 12:20 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: TREMEC 3550 and reverse
