Can a 94 gt tun with 24# inj. w/stock comp?
ok then explain why if you buy a pro-m meter it has to he calibrated for 24, 30 or any other size injectors. i just wanted to know if it would run with 24's. i will just put the 19# ones in that come stock on 94's. i am not trying to be a smart@$$ just wanting to know. just want to get the car driveable. thanks this helps. i am a betting man to but not on something i dont know about just seeking knowledge about this subject. thanks
Example...
My car has 30# injectors. If I were to put a set of 30# injectors in my car without changing ANYTHING else, my car would run rich.
why?
Because the 30# injector fires 20% more fuel (approximately) with the same duty cycle that a 24#er would.
Now, if you add a MAF that is "calibrated" it will ell the ECM that there is actually LESS air coming in, and the car will then inject less fuel by decreasing the duty cycle on the injector.
In the case of the FORD MAF's. They are not "calibrated", they have a "transfer function". the transfer function is where the X-Y comes in... X volts at Y airflow. That is what the ECM knows, you can then change the "injector slopes" to tell the ECM what size injectors it has (which all gets added into the calculations.. yadda yadda yadda)
I'll make this even easier for you... heres some pictures....
Here is the Injector slope data...
the left values are from the T4M0(value1) and the right are from the J4J1(value2)
And here is the maf transfer from both ECM's.
again, T4M0(Volts) on the left, J4J1(Volts2) on the right
The difference between a Cobra and GT is in the calibration of the ECM from the factory, not in the MAF. You are running poorly because your GT ECM is programmed to run 19lbs injectors, not the 24's you have on. Pro M basically electronically tricks an ECM calibrated for 19lbs computers to run bigger injectors by causing the pulse width and duration of the signal to the injector to decrease. It's similar to fat people tricking their stomach to feel that it is full by stapling half of it shut, Read adder's reply again as he really explains everything and he was being nice!
thanks. pony 5.0 anwsered it as did adder i guess i should have said please put it in laymens terms. but now i know alittle more about how and why it works. thanks guys will be slapping in the 19# injectors tomorrow. will let you all know if it gets to running better.
when i upgraded to 24's i got a pro-m maf with e6 injectors and the A9L did not like it at first but has since smoothed itself out.
adder what is that software and what type of plug-and-play hardware do u need?
junior04
09-28-2015 10:53 AM
