Blinky lights
Blinky lights
My son's 85 GT has headlight issues, only with the brights on. Random blinking, but only after the brights have been on awhile. Very subtle "tinking" noise under the dash near the steering column to the beat of the blinking lights. I thought it was loose wiring inside the column, but blinking happens with no vibration, engine on or off, and hands off everything. Took apart the column and everything looks fine.
The lowbeams work without issue. But then hit the high beams and after a bit the blinking resumes.
Related or unrelated problem: Car likes to die when deccelerating to a stop with the headlights on. Seemed to be related to depressing the clutch. Thought maybe it was an ignition coil, but not really sure.
Would appreciate a hint, or better yet, take me right to the problem.
Thanks
Thanks
Thanks
Thanks
I fixed this problem in my old Taurus a few years ago, too...
^^ what he said. my experience was that the breaker circuitry in the switch was bad and was heating up big time. replacing the switch solved the problem. feel the switch while it's on and see if it gets hot.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
