Mounting the rear end!
Old 11-17-2003, 08:20 PM
Glengemen
Glengemen's Avatar
Default Mounting the rear end!
I was wondering if anybody knows if a rear axle from a 5 lug stang would bolt up to my '89 that currently has the four cylinder axle in it, or do I just get thehousing from a 5.0 and stick ranger axles in it?</P>
Glengemen is offline
Old 11-17-2003, 08:21 PM
T5superduty
T5superduty's Avatar
Ya i'm pretty sure it should. But remember to buy 5 lug wheels lol
T5superduty is offline
Old 11-17-2003, 08:25 PM
Glengemen
Glengemen's Avatar
I was hoping that it would. Now I need 94-95 spindles to make the front match the back<IMG src=smileys/smiley2.gif border="0">
Old 11-18-2003, 11:00 AM
Stang153
Stang153's Avatar
<FONT face="Verdana, Arial, Helvetica, sans-serif" color=blue>an axel from a v8 stang won't work in a fox body 4cyl rear end housing. the 4cyl housing is to small..</FONT>
Stang153 is offline
Old 11-18-2003, 02:32 PM
Glengemen
Glengemen's Avatar
I didn't say I was going to put v8 axles in my housing! To convert the fox 8.5 to a 5 lug you take2 driver side axles out from 2 rangers and install them. The Question was if a newer V8 axle would bolt up.<IMG src=smileys/smiley16.gif border="0">
Old 11-18-2003, 03:05 PM
Quik
Quik's Avatar
Originally Posted by Glengemen
I was wondering if anybody knows if a rear axle from a 5 lug stang would bolt up to my '89 that currently has the four cylinder axle in it, or do I just get the housing from a 5.0 and stick ranger axles in it?</p>
the only problem with the sn95 8.8 rearend is that it is a little wider by like 3/4 inch on each side. which isnt that much of a problem jsut need to run different offsets
Quik is offline
Old 11-18-2003, 04:04 PM
Glengemen
Glengemen's Avatar
I know that after '96 the front spindles were moved out 1/2". Is this the same case for the axle or after '93 did this change?
StalkerGT
09-25-2015 02:41 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
cbird1177711
09-02-2015 08:51 PM
09-01-2015 08:16 PM
Quick Reply: Mounting the rear end!
