Hurst line lock install line help
well no steering suspension component should have much play if any, what you need to do is hold the tire steady and have someone rock the steering wheel back and worth so as to not move the tire, while such is done, inspect tie rods, steering shaft and rack mounting points , if to much freeplay exists , locate it
Suspension / Body
AJE K-Member
Chromoly Upper/Lower Control arms
Welded in sub frame connectors
Energy suspension motor mounts
Energy transmission mounts
175 Coil Overs
Strang struts
Strange 10 way adjustable struts
Aluminum Caster camber plates
GT rear springs with a right rear air bag.
mine feels like it wanders on launches and this is my set up:
chromoly u/l control arms
welded full length SFC w/ cross braces
strange 10 way in all 4 corners
eibach drag launches w/ airbag
poly spring isolators
hotchkis CC plates
stock rear sway
stock K member set up
stock rubber mounts
(remove front sway)
so i think we're experiancing no front sway issues. lol
hotchkis CC plates
stock rear sway
stock rubber mounts
(remove front sway)
hotchkis CC plates
stock rear sway
stock rubber mounts
(remove front sway)
hotchkis CC plates
stock rear sway
stock rubber mounts
(remove front sway)
Once again, you are right! The tires to come off a tad bit. I am in the process of looking for new rims and tires. The drag set up is nice but when general driving...Not so nice...LOL
