Misfire #1 Cylinder!
Old 11-25-2009, 03:28 PM
KnightStang
KnightStang's Avatar
Default Misfire #1 Cylinder!
I Have a 1995 Mustang GT 5.0. I have changed the cap and rotor, wires and plugs. I changed all 8 injectors, spark plugs and tested the compression on all cylinders. I cannot seem to find the problem with the #1 cylinder, any tips or suggestions will help...thanks!
KnightStang is offline
Old 11-25-2009, 06:59 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
how do you know cylinder 1 is misfiring??
mjr46 is offline
Old 11-25-2009, 07:05 PM
KnightStang
I took it to the shop to have diagnostics done on it and they said it was the #1 cylinder!
Old 11-25-2009, 07:11 PM
mjr46
mjr46's Avatar
hmmmm, I'd like to know what they used to determine such...?? what is the car doing??? running rough??
mjr46 is offline
Old 11-25-2009, 07:19 PM
KnightStang
yeah, idles a little rough and a little more so, when holding the brake in drive...while running, i pulled the #1 plug wire off the cap and and nothing changed, it should run rougher, if i pull the #1 wire off right, it stay the same.
Old 11-25-2009, 07:30 PM
mjr46
mjr46's Avatar
try that with another cylinder and see if it changes.........if so then go back to no 1 and check for spark at the end of the plug wire with a spark tester, if it has such then check plug, if that's good, you said you did a compression test on that cylinder.....what was compression result??? also with a noid light make sure the inj on that cylinder is pulsing, if it does the wiring is good to inj
mjr46 is offline
Old 11-25-2009, 07:40 PM
88GTBLACK
88GTBLACK's Avatar
+1 pull the plug and check if its sparking and see if the plug is wet or dry make sure the injector pulse is alright and the injector is working, and do a compression test on that cyl. But if the shop diagnosed it as a dead miss ask them why they believe its missing see if theyve already covered that stuff. It will help us help you fix your problem
88GTBLACK is offline
Old 11-25-2009, 07:46 PM
mjr46
mjr46's Avatar
also why didn't the shop go any further with the diagnosis??
mjr46 is offline
Old 11-25-2009, 08:06 PM
KnightStang
i was outside looking for the problem and i started to test the injector for voltage and in the process i found the broken wire close to the injector harness!
Old 11-25-2009, 08:16 PM
mjr46
mjr46's Avatar
see.......I was right on what to test
mjr46 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
b8checker
09-30-2015 07:11 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Misfire #1 Cylinder!
