E303 Cam
Old 07-25-2005, 01:03 AM
Quik
Quik's Avatar
Default RE: E303 Cam
you can only push out as much air as you can take in. since the stock e7s are very restrictive upgrading to a cam really isnt needed. and in alot of cases adding 1.7s or 1.72s helps out alot more along with advancing or retarding the cam.
i would upgrade valve springs even if you just did the rockers. you dont valve float and nor do you want a bent valve
Quik is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: E303 Cam
