86 flat top piston ,heads and cam question
RE: 86 flat top piston ,heads and cam question
hmmm, i didnt know that, well, i hope they are right. i would still give trick flow a call, and explain that theyre isnt any valve reliefs in the stock 86 pistons, and make them garentee that they would work b/fore i spent my money.
remember this, an ASE certified mechanic speaks the truth. we shouldnt question his knowledge about anything. [sm=groupwave.gif][sm=icon_ladiesman.gif][sm=massbounce.gif]
ORIGINAL: fastfox86
Okay, it's published on their website. The make some of the best performing parts money can buy. I'm sure they've done their homework on the subject.
I think I would check them I would not trust any one without checking them.I have seen E7 heads touch 86 pistons just from being overreved a bit on my wifes car did not hit hard enough to bend any valves but you could see very small hit spots on the tops of the pistons.someone at some time put a 86 motor in her 89 coupe.it is very easy to check piston to valve clearance and it is better to be safe then sorry.as said that is alot of money to throw away.
kawiguy827
09-01-2015 07:09 PM
