Intermintent Run Problem
Old 06-14-2010, 09:37 PM
dreamer1uk
dreamer1uk's Avatar
The TFI is also known as an Ignition Control Module for some parts stores.
They should be able to test it for you or follow the links in my other post
LUK how it goes!
dreamer1uk is offline
Old 06-15-2010, 12:33 AM
divemaster5734
divemaster5734's Avatar
My Bad.
Yeah, I'm PADI also.
Been diving since 1990. Mostly cold water high altitude and then Puget Sound.
I use a shell dry suit with argon pony for insulate.
Dont bother with doubles, too much mass when in dry suit. Buoyancy aside, your still dragging a ton and any currents are hell.
divemaster5734 is offline
Old 06-15-2010, 09:17 AM
Bubba 95SN
Bubba 95SN's Avatar
Module is beneath MAF is sitting in a heat sink. 94-95 Earlier models it was on distributor. Profile ignition pickup is inside distributor. To replace press off distributor gear and be sure to mark shaft and gear, only goes back on one way. Worth purchase of manual and test system to find the problem. Bubba
Bubba 95SN is offline
Old 06-16-2010, 04:26 PM
nitrous_bob
nitrous_bob's Avatar
Originally Posted by divemaster5734
My Bad.
oh nice....
i got certified in 2000 when i moved to cali, did all my certs there except DM. did my DM here in Michigan
i did however freedive the living hell out of okinawa, japan when i was there for almost 2 years from 1990-1992
kick myself hard for not getting cert'd there. tons of WWII wreckage everywhere.
anyways... whats the update? she running now ?
nitrous_bob is offline
Old 06-19-2010, 05:09 PM
divemaster5734
How do I press off the distributor gear?
I tried a standard puller, but it only seemed to bend the plate
Old 06-19-2010, 08:23 PM
Bubba 95SN
Bubba 95SN's Avatar
Will need a press, puller will not do. Drive out roll pin and mark gear and shaft so can press back on in correct position. 180 out and will not let roll pin go in. Pain to do, keep you from buying a cheap replacement part.
Old 06-20-2010, 09:05 AM
divemaster5734
I took the distributor into a local parts store and like an idiot I followed one of the clerks advice.
I can see why he's a parts clerk and not a mechanic now.
I don't know if it can be salvaged. I ordered a re manufactured and made them give me a discount.
It should be in today.
I need to stick to this forum, as you guys were the only one that knew what your are talking about.
I might try to get the old one fixed, but the plater that holds the sensor block windows is out of true, and I think that will damage the tfi pick up.
Old 06-21-2010, 12:26 PM
19stang88
19stang88's Avatar
never take advice from a sales clerk. as you already know
19stang88 is offline
djbigskrilla
09-20-2022 01:04 AM
KinneyD
01-09-2016 05:33 PM
Luclin999
09-07-2015 11:33 PM
jjwinel78
08-17-2015 03:34 PM
Pain.
08-07-2015 10:48 PM
Quick Reply: Intermintent Run Problem
