rebuilding t5, assembly issues
Ok guys so i got my first fox body mustang a 93 gt that was just like my grandfathers i remember riding in when i was younger (21 now) and the guy said it might need a clutch because 1 and second go in fine 3rd always grinded you could most of the time never get 4th to go in and 5th gear went in fine i knew it was tranny problem but he swore it needed a clutch. So pulling the tranny out of the car and taking off the top shifter plte showed broken in half synchro keys on the magnent and one of the ears broken off the 3-4 shift fork. I have since bought a complete rebuild kit and have gotten everything back together almost besides the 5th gear. The 5th gear shift fork seems to go in very tight like theres a clearance issue with the new shift pads sliding into the grover of the slider for 5th gear. Anybody ever had this problem?
Here is all you can ask for..pictures and a story. http://www.pomoforacing.com/tech/T5Rebuild2002pdf. Bubba
ok guys so i finished my output shaft and put it in my case the rear race slips in and goes in flush ik it should and when putting the input shaft in then the bearing retair it pushed the race out a 1/4 of an inch and the race will not fit in flush again anybody have this problem or know what im doing wrong? All of the c clips and everything clicked in as well as the spiral lock so what could it be???
yea i know the tail housing has a race built in but its like the output shaft is too long and the front input shaft bearing retainer pushes the output shaft backwards and the race doesnt seem like it would go in any further into the case even if i put the tail housing on it doesnt sit flush
TastePAINt88
11-25-2005 10:04 PM
