Sealing Headers
Old 08-31-2010, 05:19 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Default Sealing Headers
What length fasteners do i need for a 1995 with ford racing headers for the P heads? Will these work? http://www.summitracing.com/parts/STG-8913/
ryan_89_mustang is offline
Old 08-31-2010, 09:24 PM
ryan_89_mustang
anyone? are these long enough?
Old 09-01-2010, 12:52 PM
ryan_89_mustang
Alright then another question. Is it alright to use loctite on header bolts or a bad idea? And does it matter which way the gaskets go on?
Old 09-02-2010, 01:04 PM
ryan_89_mustang
anyone at all?
Old 09-08-2010, 03:00 PM
.boB
.boB's Avatar
Check the thickness of the flange and the gasket you plan to use (if using a gasket). If they're too long, they can be a pain to install in any place where the header tube makes a quick turn foreward or aft.
Don't use lock tite. It won't work. It's de-activated by heat.
Be sure to use a little tiny bit of high temp anti-seize - it's copper colored.
Here's a good installation tip. Install the bolts in about one turn. Just get them all started. Then go down the line and tighten each on about 1-2 turns. Just keep going back until they're all tight. Sometimes there's not enough room around the header tubes to install a bolt once the flange is all the way against the head.
.boB is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Sealing Headers
