Transmission Problems
Old 09-21-2010, 08:01 PM
88Mustang351W
88Mustang351W's Avatar
Default Transmission Problems
Having trouble getting my car to engage into second
It will rarely grind but someone will go like its in gear but wont pull
If I pull up on the shifter and shift very fast I can get it to engage into 2nd and it works perfect
Any ideas on whats going on?
88Mustang351W is offline
Old 09-21-2010, 09:51 PM
Bubba 95SN
Bubba 95SN's Avatar
Take transmission out, take apart. Pay close attention to shift fork and clutch sleeve for 2nd.
Bubba 95SN is offline
Old 09-22-2010, 12:37 AM
enix187
enix187's Avatar
do you have an aftermarket shifter? your shift stop may be a little out of adjustment, otherwise bent shift fork
enix187 is offline
Old 09-22-2010, 06:39 AM
88Mustang351W
haha I'll have to take a picture and show you, Sorry I'm not used to V8s I'm a Honda guy :P
Old 09-22-2010, 09:04 AM
enix187
enix187's Avatar
oh ****, you're in charlotte? so am I, yeah, take the little boot off of the shifter, and underneath that there's a rubber boot type thing thats held down with three bolts, you can take that off and tell. Of course its easer just to notice what shifter stalk is in there. the stock ford one is a semi gloss black rod thats pretty long, any other one indicates a short throw shifter. As far as repairing the trans, its pretty straight forward, I haven't had a honda manual apart in a long time so i can't give you an honest comparison.
enix187 is offline
Old 09-22-2010, 03:58 PM
88Mustang351W
Going to snap a picture right now
Old 09-22-2010, 04:02 PM
88Mustang351W
Old 09-22-2010, 04:15 PM
88Mustang351W
Yeah man I'm actually from Gastonia but thats like 15 minutes from Charlotte
Old 09-22-2010, 04:18 PM
enix187
enix187's Avatar
that looks to be a hurst, so what could be happening is when you go pull back to engage second the little bolt at the rear could be in just the right spot to jam it.
Loosen the lock nut and tighten the bolt (so it moves away from the shifter) and take it for a ride and shift it easy and see if it engages.
if that doesn't help/solve the problem then it could've been the opposite, that whom ever installed that short shifter didn't know what they were doing and didn't adjust th shift stops, then bending a shift fork when they where power shifting it.
enix187 is offline
Old 09-22-2010, 04:21 PM
88Mustang351W
I'll go give that a shot now, It's weird though because it will engage 80% of the time if I pull up hard on the shift **** and shift quick But I'll be right back with results
Quick Reply: Transmission Problems
