Engine surges hard right after KOER?
Old 11-10-2010, 06:15 AM
joes90gt
joes90gt's Avatar
Default Engine surges hard right after KOER?
The KOER test runs fine, no stumbling, no problems....Got codes 94,44,33
(secondary air pump in-op, EGR closed) Im running GT40 heads so there is no crossover tube from the smog pump to the back of the heads (i.e. 94,44 codes)
No other codes, but as soon as test completes the engine surges BAD until to feather the throttle a few times, otherwise it will surge so bad it stalls. I tried tapping on the MAF, TPS, but no difference. Surging continues to the point of stalling.
This only happens when its up to operating temp.
Cold starts of more than 6 hours are fine, with no issues. I've done a base idle reset more than I care to mention...
I cleaned MAF, TPS is set at .98, IAC is new.....Would a bad ECT cause this? What else should I look for?
joes90gt is offline
Old 11-10-2010, 09:09 PM
joes90gt
joes90gt's Avatar
Really? 105 views but not one response?
joes90gt is offline
Old 11-10-2010, 09:41 PM
enix187
enix187's Avatar
Lets see if i can make you feel better, when i first read it i thought you were talking about the test that the ecm does where it advances the timing to check it, but obviously not, have you tried the simple fix of reseting your ecu? (unplug the battery)
enix187 is offline
Old 11-10-2010, 11:42 PM
MK7JUNKIE
MK7JUNKIE's Avatar
It may be you'r MAF, my buddy dropped mine and crack the top so I took it off until i can get another one, and it sounds like your car is doing the exact thing mine is doing. While it is surging try unplugging the MAF to see if it makes a difference, if it does than most likely it is fine, however if no change I would say it is either the MAF or wiring to it. Hope this helps.
MK7JUNKIE is offline
Granatelli Sales
01-20-2020 12:34 AM
mdj89
09-06-2015 11:08 PM
whatsup62
09-03-2015 01:38 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Engine surges hard right after KOER?
