whats it for?
Old 12-26-2010, 02:22 PM
foxbod90
foxbod90's Avatar
Default whats it for?
i just recently found a vacuum leak that was causing the idle to bounce around at idle. its the long hose that runs from a canister at the passengers side to underneath the intake manifold. after that i done a few full throttle blast and i could smell and see alot of carbon. now its gone. what did i just fix? seems like i have a bit more mid range pull too!
foxbod90 is offline
Old 12-26-2010, 02:24 PM
AdderMk2
Banned
AdderMk2's Avatar
you arent running lean anymore
AdderMk2 is offline
Old 12-26-2010, 02:40 PM
foxbod90
foxbod90's Avatar
i know thats a good thing but, what exactly do u mean? i run advanced timing with premium fuel
foxbod90 is offline
Old 12-26-2010, 06:36 PM
zebo87
zebo87's Avatar
sounds like it was from part of your smog system.
zebo87 is offline
Old 12-26-2010, 07:28 PM
Bubba 95SN
Bubba 95SN's Avatar
Not lean, this means there is more fuel to burn. Correct fuel mixture=more power.
Bubba 95SN is offline
Old 12-26-2010, 10:46 PM
AdderMk2
Banned
AdderMk2's Avatar
also, if your engine is stock, or stock-ish...you DONT need premium fuel
you are actually losing some power there too
AdderMk2 is offline
Old 12-27-2010, 11:41 AM
foxbod90
foxbod90's Avatar
my timing is advanced i believe i need to run premium
foxbod90 is offline
Old 12-27-2010, 01:47 PM
89LX Coupe
89LX Coupe's Avatar
Sounds like to me you fixed a vacuum hose from your charcoal canister that was leaking and if you got the timing advanced like mine (mine's at 14*) then yes you do need to run premium...
89LX Coupe is offline
Old 12-27-2010, 02:00 PM
AdderMk2
Banned
AdderMk2's Avatar
you believe wrong. and anyone who tells you that you NEED premium, is retarded
AdderMk2 is offline
Old 12-27-2010, 02:54 PM
89LX Coupe
89LX Coupe's Avatar
I guess I'm a retard then since on my last GT with the timing advanced I tried getting away with 89 one time and my valves started pinging and put 93 back in and it stopped.... Who would of thunk it... Thanks for confirming that for me!!!
