Won't start immediately after run
Old 01-13-2011, 11:09 AM
Jabtyson34
Jabtyson34's Avatar
Default Won't start immediately after run
I'm having an issue when I shut the car off and almost immediately start it again (like at a gas pump). I'll have to put the gas pedal on the floor once and it's ok but I know something isn't right. It could sit for months and start on the first crank with no pedal, it's just in that certain situation. Possibly a rich condition right now, could that be it?
Jabtyson34 is offline
Old 01-13-2011, 07:41 PM
Bubba 95SN
Bubba 95SN's Avatar
What? You put gas to floor and then let off and it runs? Are you turning it over at this time? Go to SBFTech figure it out.
Bubba 95SN is offline
Old 02-28-2011, 07:28 PM
2008vistablue
2008vistablue's Avatar
had similar problem....ran great cold, warmed up okay....shut off and restart it didn't start. Ended up being both 02 sensors bad. GL man
2008vistablue is offline
Old 03-01-2011, 07:14 AM
92lxguy
92lxguy's Avatar
Check timing I had that problem
92lxguy is offline
Old 03-02-2011, 12:19 PM
Jabtyson34
Jabtyson34's Avatar
Actually, I'm running 24# injectors with a ported stock MAF. I have a C&L for the 24 squirters but it runs very bad with it. Yes I disconnected the battery to reset computer. I think it's for bigger injectors. I recently ported out the actual metering hole where the MAF filaments set and that helped. I guess it's all about tricking the computer. (Still need a correct MAF)
Design1795
01-24-2017 10:38 PM
Spiral534
10-06-2015 04:31 PM
Calizic
08-28-2015 01:46 PM
Design1795
08-24-2015 04:41 PM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: Won't start immediately after run
