Fuel injector regulator testing
Old 03-07-2011, 03:06 PM
witchedna
witchedna's Avatar
Default Fuel injector regulator testing
How do you test Fuel Injectors regulators for a 1988 ford mustang Lx
witchedna is offline
Old 03-08-2011, 06:36 PM
JIM5.0
JIM5.0's Avatar
Welcome to the board!
JIM5.0 is offline
Old 03-08-2011, 11:28 PM
Bubba 95SN
Bubba 95SN's Avatar
Hook up pressure gauge run engine. Pull vacum hose off no fuel should come out of hose pressure should jump from 35 up to 39. Or somethin similar.
Bubba 95SN is offline
Old 03-09-2011, 09:29 AM
AdderMk2
Banned
AdderMk2's Avatar
fuel pressure at idle with the vac line connected should be around 31-33 PSI. When the vac line is disconnected, it should be ~38-40
AdderMk2 is offline
Old 03-10-2011, 08:03 AM
droptop302
droptop302's Avatar
Increasing fuel pressure on a stock or “bolt on” Mustang is going to do more harm than good. Everyone thinks bigger is better but that is rarely the case with anything. When you increase your fuel pressure the EEC will reduce the injector duty cycle because the oxygen sensors will tell the EEC that the engine is running rich. Even worse, the EEC could get confused enough and go into limp mode causing the car to run poorly. On stock or close to stock Mustangs there is actually a benefit to reducing the fuel pressure to about 28-30lbs. This is typically worth about 4-5 horsepower across the entire rpm range. Once again, bigger is not always better. Don’t increase fuel pressure unless the engine requires it. Removing the vacuum line is not a good idea either. All you are doing there is raising the fuel pressure at idle and part throttle without changing it at wide open throttle. This will get you some worse fuel economy and most likely worse performance. If it is bad get one you can adjust and get a gauge with it.
droptop302 is offline
Old 03-10-2011, 08:12 AM
AdderMk2
Banned
AdderMk2's Avatar
none of what you just posted has ANY bearing on this thread at all. removing the vac line is a way to test if the FPR is still in good working order. If it will not hold vac, or the pressure does not change to the documented pressures when removing vac... then its bad.
AdderMk2 is offline
Old 03-10-2011, 08:28 AM
droptop302
droptop302's Avatar
I was just giving him the fundamentals on that part of the fuel system. Nothing bad in what i did.
LiquidDrink
09-29-2015 10:06 AM
Meystang
09-25-2015 04:05 PM
pimp2303
09-17-2015 08:45 PM
SteelerNation82
09-16-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Fuel injector regulator testing
