Can't get rear shocks off
Old 03-08-2011, 05:11 PM
camaroeater
camaroeater's Avatar
Default Can't get rear shocks off
Im trying to remove the rear shock and the upper nut just rotates and doesn't come off? I have it supported by the frame and the rear. I tried both sides and the nut rotates with the threaded rods its on. Anyone have any ideas?
camaroeater is offline
Old 03-08-2011, 06:54 PM
4rdnut
4rdnut's Avatar
I use a small wrench or adjustable wrench to hold the threaded stud at the top while loosening the nut, you dont need a special tool.
4rdnut is offline
Old 03-08-2011, 07:21 PM
Shelty
Shelty's Avatar
blast the daylights out of it with pb blaster...
let it soak in, then hit it with an impact wrench...
thats how mine came off. quick and easy, took an hour total
Shelty is offline
Old 03-08-2011, 07:44 PM
Riceinator
Riceinator's Avatar
if you have access to an impact gun, use that. The reason it is just spinning is probably because of the "thread lock" they put on it. If you are not re using the shocks, you can use the vise grip method mentioned above, otherwise I wouldn't advise it. If none of that works, you can try carefully heating the nut to make the threadlock a little more, ummm, loose?
Riceinator is offline
Old 03-08-2011, 08:29 PM
N3mi5is
N3mi5is's Avatar
Just reach into the fenderwell and grab a-hold of the top "tube" of the shock while you loosen the nut with a ratchet. If it's too tight to hold by hand grab it with some channel locks.
N3mi5is is offline
Old 03-09-2011, 08:21 AM
camaroeater
I tried some locking pliers on the rod and it started stripping it a little. I also, hit it with PB blaster. I think an impact gun would work best, but don't have one.
I took the shocks back and won't try again until I can find the special tool that is shaped like the top of the rod.
Nemesis, that sounds like a good idea to hold the rod from under the fender well, I'll try that too next time. I just can't beleive the first thing in 6 years that I can't do is shocks...lol.
Thanks guys!
Old 03-09-2011, 09:08 AM
AdderMk2
Banned
AdderMk2's Avatar
deep well impact socket and 6-9" extension. Put it over the nut and start bending it back and forth... You will eventually break the strut shaft. I do this on just about every old car that has that type of shock.
My S10 included!
AdderMk2 is offline
Old 03-09-2011, 12:08 PM
enix187
enix187's Avatar
+1 for impact, there's plenty of room in the hatch for it, I've never heard of a special tool for the top, why would they make the tool when just an adjustable wrench is all thats required.
enix187 is offline
Old 03-09-2011, 12:27 PM
AdderMk2
Banned
AdderMk2's Avatar
another option would be a nut splitter
AdderMk2 is offline
guitarman376
10-11-2015 01:47 AM
KingRando
10-01-2015 11:16 AM
67STANGX2
09-24-2015 12:29 PM
09-16-2015 07:53 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Can't get rear shocks off
