89 5.0 help
Old 03-13-2011, 04:15 PM
cbailey
cbailey's Avatar
Unhappy 89 5.0 help
i have a 89 5.0 that i have put victor jr heads on everything is wired correctly i have double checked everything, firing order. valves, wiring harness vaccume lines and intake for leaks. car ran perfect before now it will not idle and has a miss on cyl 5 thru 8 but runs good at wide open throtle, plugs 5 thru 8 are black and 1 thru 4 look perfect please help if you can
cbailey is offline
Old 03-13-2011, 08:55 PM
nitrous_bob
nitrous_bob's Avatar
what firing order are you using ?
did you check that TDC was on compression b4 re-stabbing the dizzy ?
nitrous_bob is offline
Old 03-14-2011, 04:45 PM
cbailey
cbailey's Avatar
the firing order im using is 1-3-7-2-6-5-4-8 and when i put the dist. back in i had #1 piston on tdc
cbailey is offline
Granatelli Sales
03-25-2016 08:01 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 89 5.0 help
