Hydraulic flat tapped lifters
Old 03-14-2011, 05:01 PM
5.0fiend
5.0fiend's Avatar
Default Hydraulic flat tapped lifters
i just bought a mild cam and was wondering do i (need) to buy new lifters as well?
5.0fiend is offline
Old 03-14-2011, 05:53 PM
AdderMk2
Banned
AdderMk2's Avatar
yes, especially with a flat tappet
AdderMk2 is offline
Old 03-14-2011, 06:47 PM
uedlose
uedlose's Avatar
with a flat tappet it is a must
uedlose is offline
Old 03-14-2011, 08:01 PM
5.0fiend
5.0fiend's Avatar
well the operating range for the cam is 1500-5000 is that going to work with the stock converter
5.0fiend is offline
Old 03-14-2011, 10:47 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
any cam will work with most convertors, will they be rockets off the line with a mismatch??....most likely not but in your case 1500 starting is not much above stock if at all...heck an h.o roller cam will out do that sissy flat tappet cam
mjr46 is offline
Old 03-15-2011, 06:33 AM
Joel5.0
Joel5.0's Avatar
If you are installing a flat tappet camshaft, aside the need for new lifters + longer pushrods, keep in mind how important it is to add a zinc additive to the oil for the break-in procedure.
Joel5.0 is offline
Old 03-15-2011, 01:31 PM
67mustang302
67mustang302's Avatar
^^ This
Additives, oil and break in procedure are critical on flat tappets.
67mustang302 is offline
Old 03-15-2011, 04:47 PM
5.0fiend
5.0fiend's Avatar
yea i bought some comp cam break-in additive, thanks guys you were a big help
5.0fiend is offline
jwog666
12-27-2021 08:09 PM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
accarter
09-21-2015 11:56 PM
uberstang1
09-20-2015 06:42 PM
Mikett
09-12-2015 10:52 PM
Quick Reply: Hydraulic flat tapped lifters
