clearence issue?
Old 06-23-2011, 01:55 AM
redneckgrunt86
redneckgrunt86's Avatar
Default clearence issue?
if i get a f303 cam with gt40p heads will i have any clearance issues with flat top pistons? not sure if it matters but im gettin tfs track heat upper and lower intake as well
redneckgrunt86 is offline
Old 06-23-2011, 05:19 AM
AdderMk2
Banned
AdderMk2's Avatar
F303... **** poor choice
AdderMk2 is offline
Old 06-23-2011, 10:53 AM
1988TTOP
1988TTOP's Avatar
more than likely u will but u know to check the ptv clearance i had a a f cam in my old 302 mine the valve reliefs in the pistons and it was close
1988TTOP is offline
Old 06-23-2011, 12:00 PM
redneckgrunt86
what would u recommend ?
Old 06-23-2011, 12:02 PM
redneckgrunt86
what cam would recommend i mean
Old 06-23-2011, 12:11 PM
1988TTOP
1988TTOP's Avatar
tfs stage one is a good cam
1988TTOP is offline
Old 06-26-2011, 09:24 PM
tinman
tinman's Avatar
Even if you use a TFS stage 1 cam or any other you always need to check piston to valve clearance.
Shoot for .100 but I'd settle for as little as .080.
The correct springs for the cam are also needed....
tinman is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
12-08-2015 04:37 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Bokeo
10-10-2015 08:28 PM
Quick Reply: clearence issue?
